Mold-Tech Material?
How to understand and apply the Mold-Tech material, and what are the differences between it and traditional plastics in application?
Tutorial here: https://www.keyshot.com/blog/how-to-use-mold-tech-texture-materials-for-keyshot/
old URL should redirect to here: https://cloud.keyshot.com which you can access from within Keyshot as well, just search for ‘Mold’ to find the relevant materials. I’m assuming you have a set of Mold-tech plates/plate binder, without or a prescribed number to use it’s semi-useless.
You can google for imagers of the plates though, just not all of them. If you’re working with a manufacturing partner they might be able to procure you a set. (I wish KS would partner with YickSang though!) Once you select a mold-tech material from teh KS cloud library you can drag it onto a part in your preview area or onto the project tree to apply the material. You can anaylize how each is made in the Material Graph.
